Home Forums Printing Discussions Printer Ink ink comming off
  • ink comming off
    Posted by Nick Williamson on 3 April 2009 at 09:00
    anyone else had this even after leaving the print to dry for three days you can still wipe the ink off.
    doesn’t happen to all prints mostly large amounts of solid colour.
    this is on orajet with roland inks and same profile all up to date have tried upping the heat but no difference (vp300)
    any ideas welcomed cheers Nick
    Nick Williamson replied 16 years, 8 months ago 4 Members · 6 Replies
    3 April 2009 at 09:08
    whats the heat settings at?
    is orajet a vinyl?
  • Nick Williamson
    3 April 2009 at 09:24
    heater 40 its a digital vinyl from the vinyl corp another name for oracal
  • Andrew Blackett
    4 April 2009 at 08:33
    Hi Nick,
    We use orajet 3164 with our SP540 and have no problems with ink coming off. Usually just leave ours 24 hours before laminating.
    Our heaters are set at 40 and 40 so I’m at a loss as to what to suggest to you mate. Is the ink wet or just not bonding?
    Also maybe try other profile sources, try orafol.de, oracal.com, roland. Seem to remember I got my "preferred" oracal profile from the orafol site but have a play around.
    Andy
    4 April 2009 at 08:44
    use you temp meter to test the temp of the bed
    if you mean it wipes off with a dry rag then try any other make of vinyl, you don’t all ways get what you ask for, so they say
  • Nick Williamson
    4 April 2009 at 10:00
    thanks yes its a 3164 oracal we are having trouble with have upt the print to 45 seems ok on small label size prints have tried profiles from roland and orafukal have noticed platten seems to be hotter one side than the other could be the problem ? next question anyone know a reasonable roland engineer or how difficult isit to change a heater element ?
    thanks again Nick
  • Nick Williamson
    4 April 2009 at 10:01
    ink hasnt seemed to bond to vinyl in answer cheers
