Home Forums Sign Making Discussions General Sign Topics incremental numbers
  • incremental numbers
    Posted by Darryl Seager on 16 September 2003 at 14:30
    Can the board assist?
    I need to print 500 labels with increasing numbers on a gerber edge,using Omega, problem is i don’t know how!
    i’ve tried going through the repeat function,i can get the digits to increase but can’t assisgn colours or put a cut box around the same to form the decal. There must be a way of doing this seemingly simple job,easily, but i’ll be damned if i can find a way around!
    If anybody has time could you please send an e-mail to the following please paul@jbtoolhire.co.uk
    cheers 😥
    Martin Armitage replied 22 years, 2 months ago 1 Member · 1 Reply
  • 1 Reply
  • Martin Armitage
    16 September 2003 at 14:47
    draw cut box correct size
    write #1 in correct colour removing cut lines and justify within box
    Select all
    Go to repeats set number of repeats x and y
    select autonumber tab
    select start number and increment ( set leading character to none )
    This should hopefully give you the correct result.
