incomplete cut when tiling
This happens alot to me when I’m cutting something on the graphtec ce3000-60.
The cutting master preview window looks like the paths are ok inside the weeding lines but when I go to cut there isn’t enough vinyl to get the weeding lines and sometimes the tops of the letters included.
Usually I just compensate and leave plenty room to make sure but this time I am trying to cut a circle for a 4×4 wheel cover that i need to flood coat and its bigger than the width of my plotter.
I’m trying to use the tiling but when I cut the first 1/2 cuts there isn’t enough vinyl and the segment is uncompleted (I hope this makes sense).
should I be using overlap? or adjusting the valid area perhaps?
My software is illustrator.
Jimmy
