Home › Forums › Printing Discussions › General Printing Topics › importing into signlab
Posted by Derek Heron on 22 January 2007 at 15:04hi all having trouble importing from customers corel file into signlab
rightly or wrongly i would normally save from corel as an a.i. then from a.i. export as eps and straight into signlab
when i am adjusting size of image to print outlines on text are distorting
any ideas
thanks
DerekDerek Heron replied 18 years, 11 months ago 6 Members · 7 Replies -
Hi Derek, have you tried to send straight to SL from Corel, click on the space ship on the tool bar mate.
Hi Derek,
I haven’t got signlab but when using corel I convert to curves then export as an eps, this then imports directly into my cutting program.
I don’t know if this is of any help to you or if i’ve got the wrong end of the stick.
Cheers John -
why not just import the ai file into Signlab? Rather than changing it to an eps which is more likely to cause a problem with signlab.
copy and paste works fine, or just drag and drop.
Hi again dodging back and forth to the unit
tried all sorts just drag and drop and seem to lose outlines or colours
just tried printing straight from a.i and corel and the print is fine just have to work out the orientation for it
thanks will check back later thanks again my spaceship aint working i must have to link it with sign lab? but not sure i used to use that with sign tools no problem
Derek -
quote Derek Heron:just tried printing straight from a.i and corel and the print is fine just have to work out the orientation for it
thanks will check back later thanks again my spaceship aint working i must have to link it with sign lab?quote Marcella:why not just import the ai file into Signlab? Rather than changing it to an eps which is more likely to cause a problem with signlab.Derek, I believe Marcella has largely nailed it. If I understand your original post, then you are doing the following:
- You have received a Corel CDR from a customer.
- You opened the CDR file in CorelDraw, and then exported as an AI file.
- You then opened the AI file in Illustrator.
- And from Illustrator, you exported as an EPS file.
- And finally you imported the EPS file into SignLab.
It does not seem practical to have all these steps, though I suspect you are doing this because you are trying to retain certain elements of the original design.
To reduce the number of steps, I suggest that you open the CDR file in CorelDraw and then go File >> Publish to PDF. There are additional PDF export settings that you might be interested in, such as embedding font information.
Nick’s suggestion was good: open the CDR file in CorelDraw, click the Application Launcher (the little spaceship, as you say), and choose CorelDraw to SignLab. If this is being troublesome, then would you mind contacting CADlink Tech Support to help with the issue. The expectation is that this is working for you, and perhaps a patch is in order?
Regards,
Rod at CADlink
thanks again all i will contact cadlink to see if a patch is in order
thanks again
derek
