Home Forums Software Discussions General Software Topics Impact Vehicle Outlines
  • Impact Vehicle Outlines
    Posted by LeeMorris on 26 November 2006 at 11:07
    I have downloaded a sample vehicle outline from impact.
    If i do a design on one of these vehicles does it automatically cut it the right size for the vehicle design?
    Cheers Lee
    James Martin replied 19 years ago 11 Members · 18 Replies
  • 18 Replies
    26 November 2006 at 11:11
    hi lee 😀
    i always double check the size of vehicle to be done…for peace of mind 😀
  • Andy Gorman
    26 November 2006 at 11:39
    The Impact outlines are pretty good. I never check the measurements, just don’t go too close to panel edges. Also, don’t trust the panel shapes exactly, for example, don’t make a magnetic panel to the shape from the outline – they’re not THAT accurate. For general lettering etc they’re just fine.
    Some of the badge positions are wrong, though.
  • Alan Wharton
    26 November 2006 at 12:46
    i think you will find you will need to up the size of impact outlines to 2000% to get the actual size, as a rule of thumb a std number plate is 520mm so i always measure that on the outlines to get it right.
    Have you now got some vinyl gfx software lee ie: signlab/flexi/vmp or you using photo shop etc.
    26 November 2006 at 13:36
    is that not only on the older impact disks alan? i could be wrong mate but i thought the scaling up of outlines was either only for certain file types or older disks. i only use the cdl files for signlab and when you open them they are already to scale.
  • Brian Hays
    26 November 2006 at 13:45
    On the disk they are supplied actual size & 1-20 scale.
    If you have downloaded the samples they are 1-20 so you will need to resize them. Some programs will not be able to import the vehicles full size, that is why the samples are scaled down.
    What software are you using Lee?
  • LeeMorris
    26 November 2006 at 15:14
    I’m just practising on coreldraw at the moment hopefully will be getting Graphtec cutter that comes with drivers to cut from coreldraw.
    Lee
  • Alan Wharton
    26 November 2006 at 17:03
    On the new 2007 library i got from impact last week i just had a quick look at a few vans and i brought them up to 2000% in flexi and that was the actual size, i carnt remember what file type i imported the outline as so there may be a full size file in there but i havent had time to have a good look at the disc/files yet. Btw thx for the quick delivery from impact 😛
  • Richard Urquhart
    26 November 2006 at 21:11
    i use the esp file as there full size
    rich
  • Kenny Ramsey
    27 November 2006 at 13:10
    I’m only on 2003 at the mo but it has Full size and to scale.
    Regarding sizes, they are pretty accurate and I would only normally check if I’m going right to an edge with text etc
    THe only thing I find tricky sometimes I distinguishing between panel gaps, recesses, bulges etc
  • M Brown
    27 November 2006 at 13:21
    Hi Alan,
    How much did you pay for the new version 21 outline disk, and how much was delivery.
    I just phoned Impact twice for a price and they havent answered the phone once. I hate that. All I want to do is place an order
    from
    Mark
  • Kenny Ramsey
    27 November 2006 at 13:23
    Its usually £100 I think
  • Alan Wharton
    27 November 2006 at 13:40
    Kenny is right with the price although you can get substantial discount if you are full gold member of the ukboards, so its well worth thinking about upgrading your membership. 😉
  • Alan Wharton
    27 November 2006 at 13:42
    ps. or i think its gold but il be corrected if im wrong 😀 🙄
  • Lorraine Clinch
    27 November 2006 at 13:43
    UKSG! 😛
  • M Brown
    27 November 2006 at 13:48
    I can get it from Grafityp for £85 including free delivery, all I got to do is wait till there ver 20 has ran out.
    How come there selling it cheaper
  • Kenny Ramsey
    27 November 2006 at 14:12
    Just paid for gold over the weekend but maybe I’ll upgrade to UKSB straight away 😀
  • James Martin
    27 November 2006 at 18:23
    I did my first van recently using impact with illustrator and was wondering about the scaling problem so I phoned impact.
    The files they supply for illustrator need to be increased by 2000% as has already been mentioned. There in a folder called (AI 1-20).
    For corelDRAW6+ there are files at the correct size on the disk in the folder (EPS).
    For coralDRAW pre 6.0 you have to use the same 5% scaled down drawings as with illustrator.
    I just copied all the vehicle outlines and pasted them into a new file, scaled them up by 2000% and cut.
    there is probably a better way but u live and learn.
    Jimmy
  • James Martin
    27 November 2006 at 18:26
    Oh. and I paid £116.33 including VAT.
    Jimmy.
