Home › Forums › Software Discussions › Corel Software › impact vehicle outlines
Posted by Martin Parker on 7 July 2010 at 13:08can you make these full scale in corel and if so how do you do it and what do u import it as
thanks
Martin Parker replied 15 years, 4 months ago 4 Members · 10 Replies -
hi brian take it i just import the eps file in and it should be full size
also i am looking for a fiat 500 outline that isnt on the disc
You don’t need to do anything when you import the EPS files (size wise)
The Fiat 500 has been on the disk a while. You must have an old version.
quote Brian Hays:And you have it! 😉
Ahem…….what, where, why……….. I feel hurt 🙁
in corel, import the file using the eps/pn/blah blah filter, not the eps filter, then it’ll come in at 100%.
do check important measurements though, they’re pretty accurate for general work but, if you’re gonna be going close to edges or using swage lines as guides, measure first and compare against the drawing, some vehicles vary in swage line position etc, never by much but worth mentioning.
i keep promising myself an upgrade to a newer version, one day!
