Home › Forums › Software Discussions › General Software Topics › Impact Graphics Vehicle Outlines – What is the Scale Ratio?
Posted by Craig Ross on 25 January 2012 at 00:37Hi,
Does anyone know what scale Impact Graphics work to on their vehicle outlines?
Craig.
Alan Drury replied 13 years, 10 months ago 8 Members · 14 Replies -
If your working with cdl files its actual size and I think some of the other formats are actual size too.
Alan D -
What is a CDL file?? I cant open them on my computer and normally the EPS files.
I’ve got AI.
Its not the actual size on mine. Maybe I’ve loaded it wrong?
quote Harry Cleary:CDL = Corel Draw file
Isn’t Cdr – Corel Draw 😉
quote Gary Birch:quote Harry Cleary:CDL = Corel Draw file
😳 I shouldn’t be up this early in the morning! 😀
EPS are actual size. I load those straight into Flexi.
Ai files are 1:20 when using illustrator. -
Whats the easiest way to scale the image up to actual size in illustrator? Any ideas?
Workspace too large for that though. Coral Draw it is I think…
Sorry if that was flippant Craig.
Just increase your workspace.
File – Document Seup – set to 5000mm each way should cover a vehicle.then
Select All – Group – transform – scale – enter 2000%.
that should be actual size and fit on your workspace. -
CDL is Signlab – corel Draw is CDR – Ai is scaled probably because Illustrator does not support large page sizes to the same degree as Corel Draw or a bespoke sign programme.
Corel Draw will import eps but depending on version you use look for the PS import filter.
Alan D
