Home › Forums › Sign Making Discussions › Vinyl › im looking for supplier of truck vinyl please?
Posted by Ian Higgins on 15 February 2005 at 16:42Hi all,
Looking for a supplier of truck vinyl to letter up a curtain sider. Has anyone got experiance of using this ? If so is it any good?
IanIan Higgins replied 20 years, 10 months ago 4 Members · 4 Replies -
If you use the search you will come across many posts giving views and where to buy!
http://www.uksignboards.com/viewtopic.p … =apa#67766
http://www.uksignboards.com/viewtopic.p … =apa#14850
http://www.uksignboards.com/viewtopic.p … =apa#10343
http://www.uksignboards.com/viewtopic.p … t=apa#8209
http://www.uksignboards.com/viewtopic.p … t=apa#3195
http://www.uksignboards.com/viewtopic.p … t=apa#3009 -
thanks for the back links budone.. nice one mate 😉
higgi ive used apa’s many times.. sticks like the brown stuff 😉
apply dry but definately have a second set of hands… you need help holding vinyl hovering as you apply. once stuck your not moving it again…
apply with felt squeegee as a nylon one digs into curtain at the edges mate…i have a huge contract that we may get and it involves this stuff..
im gonna call for some samples i think as i will have to profile it myself to print onto 😕 -
Rob wrote
quote :apply with felt squeegee as a nylon one digs into curtain at the edges mate…Never had a problem with the good old goldies! Personally I would not use a felt squeegee as I don’t think you get enough pressure. Not that you can press to hard when applying to a curtain I just prefer the stability of a nylon. When applying hold the squeegee fairly upright to the surface, don’t have to much angle on it.
We also use APA curtain alot and never have a problem and its cheaper than Avery, although sometimes get stumped on colours and have to use it 😕
Other pointers
Tighten up the curtain as tight as possible
Clean the applying areas properly and meths after
As Rob said another pair of hands
Stay out of the wind!Good luck Ian
Lamby
