Home Forums Vinyl Cutter Discussions Roland Cutters im having blade problems with My Roland CX24 help please?
  • im having blade problems with My Roland CX24 help please?
    Posted by Roy Roberts on 9 November 2004 at 19:23
    😕 Hi All 😕
    Having problem with the CX24 since I changed the blade? (!)
    I purchased a blade from a very reputable 🙄 company 🙄 which once fitted did not seem to cut right. (EDGES NOT SMOOTH AND LETTERING NOT CUT CLEAN SNAGS IN PLACES).
    Blade looked different from original, I rang them and they sent me an original blade :lol1: (had to pay for both still), 😕 But problem still there. 😥
    Both these blades look different from the one in the machine.
    Any Suggestions?
    Roy Roberts replied 21 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • signworxs
    9 November 2004 at 22:07
    Had a similar problem to this a while ago, the vinyl had a jagged almost perforated cut line as if the blade was skiping along the surface,does that make sense. After trying several blades I discovered that the bearing in the blade carrier was worn. If you screw off the depth adjuster on the end you will see the small bearing, insert a blade and wobble to see if there is any play. Luckily I had a PC50 that gets no use and tried the blade carrier from that and the problem was solved.
  • budone
    9 November 2004 at 22:15
    Could be your off-set, if your old blade was worn you might need to adjust the off set of the new blade.
    I think the smart blades that harry sells are brilliant, never had any problems at all with them
  • Roy Roberts
    10 November 2004 at 17:37
    😛 Thanks for the help 😛
    Checked the blade roller all OK also no change when adjusting the off-set,
    Ordered a couple of cutting strips (blade protector strip).
    Roland think it could be that.
    Thanks again for your help.
    10 November 2004 at 17:48
    i think mr signworx was on the case remove the blade and blast out the bearings inside the holder with wd40 one little bit of grit is all it takes to do as you discribe
  • Roy Roberts
    10 November 2004 at 17:56
    Cheers Chris,
    😉 WD40 😉 I am on the case now,
    Will Let you know how I get on.
    Roy.
  • signworxs
    11 November 2004 at 00:17
    When you change the neoprene strip make sure you get ALL the sdhesive out of the channel or you will have worse problems. From experience 😳
  • Roy Roberts
    11 November 2004 at 11:03
    😀 😀 Thanks Chris The WD40 Worked 😀 😀 used about 1/4 tin.
    Thanks again Paul will still change the strip but take notice of your tip on adhesive.
  • Steve Broughton
    11 November 2004 at 12:16
    ANY plotter probs ring Harry first
    http://www.blades.uk.com/?t=1439
    the all knowing genie of plotters
  • Roy Roberts
    11 November 2004 at 12:43
    Cheers Steve, 😉
    Put Link On My Favorites.
    Called past your place two weeks ago, I take it its on the Main road into Boston on left hand side.
    Roy.
