Home Forums Software Discussions Adobe Software Illustrtator step and repeat
  • Illustrtator step and repeat
    Posted by Lanza on 18 May 2009 at 10:48
    Hi does anybody know of a plug in for Illustrator CS2 and or CS4 I know InDesign has the function but I don’t want to keep swapping between programs.
    Cheers Tony
    Lanza replied 16 years, 7 months ago 7 Members · 12 Replies
  • 12 Replies
  • Jeremy Howes
    18 May 2009 at 11:17
    Hello Tony,
    Have a look at something like stepX by Esko Artwork, I don’t use it myself but I’m sure that this or something similar will do the job.
    Jeremy
  • Gary Pickles
    18 May 2009 at 20:08
    Select the object you want to Step and repeat.
    Right click and select transform and move
    enter the amount you want to step the object and press copy
    the copied item should now be selected
    Press CTRL D to repeat as many times as required.
    Not exactly Step and repeat but works well.
  • Jason Davies
    18 May 2009 at 20:11
    OR with the pointer tool selected just hold the alt key down, click and drag, this will duplicate the object and then just hold either the apple key down or ctrl key and press D, this will step and repeat, if you hold the shift key down at the same time when you initially duplicate you can keep everything in line.
    Jason
  • John Childs
    19 May 2009 at 08:45
    The way I would do it is to use the "move" command.
    Select the artwork you want to repeat and press the "Enter" key.
    A dialogue box comes up where you specify the distance you want to move, then press "copy".
    That leaves the copy of your artwork selected so, from there you just keep pressing "enter" and "copy" in turn until you have as many as you want.
  • James Martin
    19 May 2009 at 09:35
    Good tips there.
    Nothing better than a work flow shortcut.
  • Jason Xuereb
    19 May 2009 at 09:37
    Once you’ve done what John said once you can hit CRTL + D to just keep doing it.
  • John Childs
    19 May 2009 at 09:44
    quote Jason Xuereb:
    Good tip Jason. Thanks.
    On a Mac it’s CMD + D though.
  • Lanza
    19 May 2009 at 11:35
    Hi all.
    Thanks for all the tips (wow) will try them out when I next get some free time I’m up the wall at the moment!
    Still feel adobe are missing out on a function they could easily combine,
    think I may rattle their cage.
    Thanks again. Tony
  • Jason Davies
    19 May 2009 at 19:38
    Hi John, sorry old school cmd is the Apple key.
    Jas
  • John Childs
    19 May 2009 at 20:00
    quote Jason Davies:
    I know Jason. I was looking at a new keyboard at the time though, and saw the Apple key had been replaced by CMD. It was the first time I’d noticed. 😀
  • Lanza
    20 May 2009 at 07:23
    Hi I’ve just tried Johns tip combined with Jason’s and it just what I was looking for, I thought there must have been a better way than copy &
    paste. Thanks everyone for the input.
    Cheers Tony
  • Lanza
    20 May 2009 at 12:37
    Not sure where my last post went but Johns tip did the trick along with Jason’s, I thought there had to be a way.
    Many thanks this will make my life a lot easier not having to copy and paste.
    Cheers Tony
