Home Forums Sign Making Discussions General Sign Topics Illustrator to versaworks question ?
  • Illustrator to versaworks question ?
    Posted by Shaun Cleary on 12 August 2010 at 11:58
    I am making a file to an exact size in EPS (60mm x 20mm) and then importing it to versaworks, only problem is for some reason versaworks is making it so the closest I can get is 56.81mm x 20.22mm.
    Does anyone know why this is and how to fix it ?
    Jason Xuereb replied 15 years, 4 months ago 2 Members · 2 Replies
  • OwenTaylor
    13 August 2010 at 13:44
    maybe you have a clipping mask or some invisible artwork that is changing the size. Try saving as a pdf or put a white square 60mm x 20mm at the back of your eps file.
  • Jason Xuereb
    14 August 2010 at 06:48
    EPS don’t contain document size elements. It will save the file as the size of the total size of all elements in the artwork.
    PDF works with document size.
    So as been said save as PDF or put a white square behind your artwork.
