Home Forums Sign Making Discussions General Sign Topics Illustrator spot colour help ???
  • Illustrator spot colour help ???
    Posted by Shaun Cleary on 18 May 2010 at 17:05
    I am having a problem with a customers artwork in illustrator, I have the cut line ready and save it as an EPS.
    It then comes up with
    (When spot colours are used with transparency, changing them to process colours outside of illustrator can generate unexpected results).
    And I click continue and import it into versworks and no cut line shows.
    Thanks shaun
    Shaun Cleary replied 15 years, 7 months ago 3 Members · 3 Replies
  • Dan Osterbery
    18 May 2010 at 17:30
    Hi shaun,
    i get this quite a lot! I have found sometimes putting cut contour on a different layer and the top layer works! Sometimes it doesnot and i have had to flatten transparency and rasterize artwork, then add the cut contour and it works! If you find a permanent fix i would love to know! I am using CS3 by the way, and it only happens rarely! goodluck
    Dan
  • Lee Attewell
    19 May 2010 at 01:10
    What Dan said Shaun but have you also tried printing as a pdf?
    This sometimes sorts it out.
  • Shaun Cleary
    19 May 2010 at 10:18
    Thanks Dan, I had to export to photoshop and flatten + rasterize, save as PDF and export back to Illustrator.
