Illustrator remembering both parts of a combined path
Hi Folks,
Been using Illustrator CS2 (MAC) for some time now and I’ve begun to use it alongside the plug-in for a cutting/plotting machine. It’s a Graphtec CE3000-60 – loving the machine by the way.
If i create a path from scratch it all works fine – the blade cuts exactly where you’d expect it to go.
However, if I use a compound path – ie. a shape created from two or more paths combined in some way I get the wrong result.
For example, say I have a circle and I want a wavy flame shaped line to run through it. The easiest way is to draw a circle, draw a flame outline, select both and use the pathfinder tool to exclude the flame from the circle – I end up with a good visual on screen which looks like a coin with a flame running through the centre of it, but when I come to outputting the symbol to the cutter it cuts out the full circle AND the full flame – basically the outline that you see when you select the object in illustrator.
Another example would be having a piece of type cut away from a rectangle. If I used the letter ‘b’ the the hole inside the b would disappear altogether when I picked out the b shape from the rectangle, so what I would do is draw a thin rectangle alongside the verticle line of the b convert the b to outlines, use the pathfinder tool to exclude the thin rectangle from the overall shape of the b – that way the centre of the b stays – hope you’re getting this – a bit like using the stencil font! However, the software doesn’t recognise the combined path so not only does it cut out the full ‘b’, it also cuts out the thin rectangle!
I’m sure that someone out there knows exactly what I’m talking about here – hopefully!
I’ve just come back to these signboards after about a year or so, so hello to all of you once again. Have a bit to tell, and will catch up once my little lad stops wanting to watch Thomas the Tank Engine (for the hundredth time!)
