Home Forums Software Discussions Adobe Software Illustrator Question re strokes
  • Illustrator Question re strokes
    Posted by John Harding on 7 March 2014 at 08:51
    Hi Guys In flexi there is a "convert stroke to outline tool" – whats the method to do the same in illustrator please
    Thanks in advance – John 😀
    John Mackenzie replied 11 years, 8 months ago 4 Members · 4 Replies
  • Martin Oxenham
    7 March 2014 at 09:21
    In Illustrator the Stroke is the outline. Thats how you make an outline in Illustrator and why you have to convert it in Flexi.
  • Martin Grimmer
    7 March 2014 at 09:33
    Following on from Martin, if you need to convert the outline, select it, then object>path>outline stroke.
    Martin
  • John Harding
    7 March 2014 at 10:21
    Both Martins thank you for your time 😀
    Martin Grimmer spot on what I needed you get todays gold star :thumbup2:
  • John Mackenzie
    12 March 2014 at 15:51
    quote Martin Oxenham:
    The stroke isn’t an outline hence the need to convert the stroke as posted buy Martin G, also John you may already know but you can create an outline from a path without creating a stroke and then converting it by highlighting the path you want to outline and then selecting Object>Path>Offset Path, this creates a vector outline around the selected path.
