Home Forums Software Discussions Adobe Software Illustrator CS6 and Graphtec Cutting Master 2
  • Illustrator CS6 and Graphtec Cutting Master 2
    Posted by Kevin Polston on 2 June 2012 at 09:06
    I’ve just upgraded to Illustrator CS6 but can’t get Cutting Master 2 to work with it (I use a Graphtec cutter). I’ve emailed Graphtec and am awaiting a reply.
    I just wondered if anybody else is in the same situation?
    Kevin
    Rick Hyde replied 13 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Daniel Evans
    2 June 2012 at 09:23
    Sorry, i’ve got no helpful advice but ‘School Boy Error’ comes to mind
    Hope it’s on a spare machine, I take it you’ve got the very latest cutting master 2 update for lion?
  • Kevin Polston
    2 June 2012 at 09:38
    I don’t think I’ve made an error – I just think Graphtec haven’t upgraded the plugin yet. I still have CS5 working so I’m not stuffed!
    2 June 2012 at 09:50
    i suspect Kevin is right, we were in the same situation with Corel draw last time around.
  • Alex Pirozek
    2 June 2012 at 10:17
    I suspect you’ll need the latest CM2 that’s compatible with CS6.
    I upgraded to Corel X6 and found the same problem with CM2 not working.
    Just looked at graphtec’s website and there’s an updated CM2 version that supports the new Corel X6 so an updated CM2 that includes CS6 might not be that far away either.
    Just downloading it now so hopefully we can start to use X6 from now on.
  • Rick Hyde
    30 July 2012 at 11:31
    I have just upgraded to CS6, but am still using my original CS4 for my cutting. (they both run fine on my pc)
  • Joachim Kurz
    5 August 2012 at 12:17
    Hello,
    Cutting master 2 for Illustrator CS6 is now available.
    I have just downloaded, installed and tested V1.8.8.
    It is available at : http://www.graphtecamerica.com/support/
    regards
    Joachim
  • Rick Hyde
    6 August 2012 at 15:10
    Many Thanks Joachim, I have now downloaded CM2 & all is fine in CS6!
    Rick
