Home Forums Sign Making Discussions Neon, LED, Lighting Illuminated signs & cable glands advice please?
  • Illuminated signs & cable glands advice please?
    Posted by Kevin Flowers on 14 July 2003 at 18:26
    Since starting in this business approx 2 years ago, i have continually seen illuminated signs fitted up an working without any form of entrance/exit wire protection. It seems common practice to drill a hole poke cable through and wipe a bit of silicon around. I come from a general engineering back ground covering mechanical and electrical work an have always fitted IP65 cable glands to all illuminated signs and junction boxes and if providing all wiring then also fitting a RCD and firemen switchs on certain signs. Is there guide lines for the installation of illuminated signs etc i know people are probably thinking that its just your small sign shop not doing it but it is not i have looked at signs installed by corporate sign companies and have came across the same. A IP65 cable gland costs about £.50p and gives a safe professional look to that very nice sign you have just fitted.
    Whats your opinion should you spend the £.50p or not do you fit them now.
    (honest answers please)
    Mark Horley replied 22 years, 5 months ago 6 Members · 6 Replies
  • Geraint Rhys Williams
    14 July 2003 at 20:12
    I also come from an Electrical Engineering Backround.
    I would say that proper glands should be used (Im not actualy trading as yet) – I would certainly use glands etc and definately follow the guidelines of the 16th edition regulations.
    I doubt if there is an actual code of practice for shop signs etc but there is for traffic signs, and they definately have full glanding/earthing etc.
    I would also like to think that following the 16th edition regulations would give you back up should anything go wrong (ie if someone else services your sign and gets a shock etc).
    At the end of the day, with a gland, the job is not only safer, but it looks a lot tidier and is more importantly safe!!!
    Thats my thoughts anyway!!!!
    Rhys
  • Simon Clayton
    14 July 2003 at 20:30
    I used to work for one of the counties biggest sign companies, about 15 years ago doing surveys
    One problem we used to get was fitters didn’t put the porcelain pots on the neon,
    Many times I would get called to site and find a whacking great hole melted through the metal back tray, were the cable had been flapping about in the wind.
    A lot of people can’t be bothered, that’s why I like to get the site sparks to do it, that way if the shop burns down through an electrical fault it down to them.
    Simon
  • Mike Grant
    14 July 2003 at 20:50
    I think this is down to 2 things
    IGNORANCE & LAZYNESS
    It’s the Cowboy element in the industry who just can’t be arsed to do it properly, how many times have you seen perspex and PVC signs just screwed to fascias without the proper sign frame.
    I rest my case.
    And yes WE DO use the proper glands.
  • Kevin Flowers
    14 July 2003 at 21:29
    quote Rhys9918:
    Rhys
    The 16th edition is probably not something a majority of sign writers would know of however common sense should be the order of the day.
    1. you dont pass an electrical cable through a metal hole without providing secondary protection against shaffing etc
    2. if you go to all of the measures to make the rest of the sign box water tight then it stands to reason that you should not have water coming in with your electrial supply.
    3. the correct cable (a)for the relevant amp draw of the light box (b)the correct grade i.e armoured or at least an outdoor grade of cable.
    I actuall saw a projecting sign wired in with a piece of twin and earth and no gland the real daunting thing that it was on a major sign franchises shop and to top it of fitted with 21/2 inch bolts with about 2 inchs of thread showing.
  • rob@rjbsigns
    14 July 2003 at 22:14
    The wiring regulations you need are BS7671 book form £47.00 or cd rom £350.00 from the IEE web site
    http://www.iee.org/Publish/Books/WireAssoc/index.cfm?book=WR 230
    hope this helps 😆 😆
    Rob
  • Mark Horley
    14 July 2003 at 22:51
    Its amazing what we see on our travels…
    I’ve seen live cables twisted and covered in chewing gum
    The sign switched through the neutral on a fused spur (always live)
    Conduit box’s filled with silicone instead of lid & gasket
    Neon transformer wired to E instead of earth
    the list goes on…
    All we can do is do it right first time.
