Home › Forums › Printing Discussions › General Printing Topics › illuminated shop fascia sign print
Posted by Shane Toon on 22 June 2018 at 08:44Hi Guys.
just having a bit of a head scratch, as its been a while since ive done one.
i have an illuminated box fabricated up, with opal perspex.
im running a mimaki cjv-150-160.
would you recommend printing the print on clear or white vinyl?Pane Talev replied 7 years, 6 months ago 6 Members · 7 Replies -
Hi Shane.
Personally, I’d use a translucent white, seems to diffuse the light better. Metamark do a good one. -
Am I missing something here?
Printing/cutting white vinyl onto
an off-white (opal) panel?
Barry -
I’m assuming he’s printing the whole panel, so I would use a translucent white rather than standard white vinyl. Works fine for us
agree with Kevin, I use the metalmark translucent and satin laminate then apply to opal acrylic, works fine
Or, if you have any, use a digital white with a clear adhesive.
What you need to be careful with is, depending on the printed graphic / image, when illuminated, it may look washed out slightly once illuminated. There are various ways you can strengthen the colours in photoshop by tweaking them.
There can be a trade-off issue though. once the colours are deepend it may look a little heavy/dark during the day. -
Having tried different methods and taken advice from this board i now print on my clear laminate (polymeric). It does the job just fine.
quote Kevin Mahoney:Hi Shane.
Personally, I’d use a translucent white, seems to diffuse the light better. Metamark do a good one.Same as Kevin’s advise.
