Home Forums Sign Making Discussions Vinyl ideas please for a glass looking effect on windows?
  • ideas please for a glass looking effect on windows?
    Posted by Carrie Brown on 22 April 2003 at 10:36
    Hi, 😀
    I have a client who wants "something different"
    We have a glass panel approx 1800x500mm above the entrance doors, the client wants the company name put onto this glass but not using vinyl. As stated above they want "something different"?
    We have thought about using acrylic built up letters – possibly glass looking effect…… but…… can we stick the letters to the glass without any glue residue showing on the other side, has anyone ever done anything like this before?
    Any ideas welcome….?? Has anyone got any suggestions on what we could do with this panel, not using vinyl & the client is happy to spend whatever is necessary to get the right effect…… eye-catching, modern & different?
    Thanks 😀
    steve replied 22 years, 7 months ago 10 Members · 10 Replies
  • 10 Replies
    22 April 2003 at 10:53
    Have you suggested using etched glass vinyl?
    Many clients are not aware that this effect can be created using vinyl – they see etched glass windows and assume it has been done by sandblasting the glass.
    22 April 2003 at 11:58
    what about stained glass.. using transparent film and adhesive lead strips..
    gluing to glass without glue showing is done with a glue called perma-bond.
    they use it to glue chrystal bevels to windows.. you onl need a small drop and its cured with a UV light.. Sets in about 3-4 seconds.
    glass trade suppliers sell it
  • ruth
    22 April 2003 at 12:20
    Carrie,
    There is a window I pass quite regularly which is simply decorated with an irregular coloured glass bead in the middle of each pannel, very striking! It looks as though it is stuck on with silicone but it must be something more than that. The glass stones are commonly available in craft shops, why not create a mosaic of glass stones to create the shop name. A simple light on the inside will turn that into an attractive nighttime display?
    Just a thought
    Ramjam
  • Simon Clayton
    22 April 2003 at 12:35
    What about real sand blasting…I once see a sign that was done on both sides to a depth of anything from 1mm to 12mm. It was a world map in total relief… looked fantastic!
    They were glass dividing panels, you just had to go up and touch it, run your fingers over the contours 😳
    Does the client have any artwork to go on…business card etc.
    22 April 2003 at 16:55
    Phil mentioned using etched glass vinyl and said that a lot of people did not know what effects could be achieved. This is very true, I have a glass panel with about 20 different window films on it. These are all vinyls designed especially for windows, there is a range of colours and effects available. Have a look at the Hexis web site, you might be surprised just how many window films there are.
    http://www.hexis.co.uk
  • Alan
    22 April 2003 at 18:06
    I suppose getting out the paint and gold leaf is out the question?
  • Mike Grant
    22 April 2003 at 22:11
    Carrie, If you want to go the built up letter route, to hide the back of the letter simply cut out a mask to go on the inside of the glass to follow the shape of the lettering. This could be done in the same material as the lettering. Once the main lettering is up just simply stick the mask to the back. Problem solved no ugly glue marks from either side.
  • Carrie Brown
    23 April 2003 at 08:28
    Thanks for the input & great ideas everyone 😀
    We already suggested the etch vinyl to the customer, who is quite happy to use it but only as a temporary measure until they decide which alternative they want? They want something different to what everyone else has, not using vinyl or paint or sandblasting …………….. Im sure what they want hasn’t even been discovered yet?
    We like the idea of using letters which look as though they have been cut out of ice, with a frosted effect on the face……….. nice idea, customer seems to like the idea aswell……………. we just have to find a supplier now (?)
    Thanks again 😀
  • Tim Shaw
    23 April 2003 at 16:54
    Some of the bigger glass suppliers have large format glass engraving
    facilities.
    my local Yates wine lodge as some beautiful engraved panels above the seats and in the dividing door panels.
    A firm in Whitby called Cowans have this facility but I have know idea about costs, file formats etc.
  • steve
    24 April 2003 at 07:21
    carrie hows about an LED moving message panel with their logo programmed in its great as people can not ignore one of these babies he could put on time and temperature info ..anything to get it looked at not the cheapest solution but innovation never is we all look at that type of info also looks good at night when all other signs are asleep!!
