Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters I’ve networked my USB FC8000-130
  • I’ve networked my USB FC8000-130
    Posted by David Hammond on 22 June 2011 at 09:48
    When I took over the company my plotter was USB driven so had to be located within distance for the wire to reach the Mac.
    I have looked at getting a USB-Ethernet print server, in the hope that it would work, as you can configure the plotter using Cutting Master to use an IP address.
    I ordered a Edimax PS-1206U USB2 Single Port Print Server – The grand sum of £32.36 incl VAT & delivery.
    Plugged it in and has a mess around with it, It works. 😛
    So I can relocate the plotter anywhere within the office! I have made a little more space now, and if I get a larger job I can move the plotter for easier access.
    Just thought I would share that with you all, incase you too struggle with a USB plotter.
    David Hammond replied 14 years, 3 months ago 6 Members · 12 Replies
  • 12 Replies
  • Robert Kulawik
    23 June 2011 at 14:20
    You just solved the problem I didn’t know I had! Off to get one now- Cheers! 😀
    23 June 2011 at 14:21
    You will need a PC to install the driver and set the IP, but then go no further, just use Cutting Master to cut.
    I got mine from scan.co.uk 😉
  • Robert Kulawik
    23 June 2011 at 14:37
    Many thanks for that David 🙂
    23 June 2011 at 14:42
    No Prob… PM if you get any prob’s and I will help as much as I can.
    Feels good to give something back to the site.
  • Kevin Polston
    16 July 2011 at 19:08
    David what operating system do you use?
    Kevin
    16 July 2011 at 22:06
    I run cutting master illustrator plugin on mac osx. Installed the print server on windows 7
  • Peter Holt
    4 October 2011 at 08:42
    am just setting up yet having network issues with my ce5000 and dont really want to have to buy another mac or pc to act as a print server slace for my epson b1100 and the ce5000 so i wonder if this will work for this as well….. any else tried on a ce5000?
    4 October 2011 at 09:04
    I’m quite surprised you not have any issues…. can u let us know after a week of using it how its performing?
    4 October 2011 at 09:06
    My plotter was working great with the exception of the poll size in cutting master.
    Upgraded CM, and now it doesn’t work via the network.
    Instead I bought a USB extension cable from Play.com and it works a treat
  • Stafford Cox
    4 October 2011 at 09:34
    That’s a good find David, thanks. The amount of Mimaki cutters I’ve had to install via USB and tell the customer to just run around the office with the cable, plugging it in to each Mac and PC is countless!!
    Thanks for posting 😉
    4 October 2011 at 14:01
    ah so it doesn’t work.
    yes its the polling that worried me
    4 October 2011 at 14:03
    it was a toss up between having no space, and poll size.
    The plotter worked fine until I updated CM2.
    My general opinion and path I have taken was to get one one these
    http://www.play.com/PC/PCs/4-/3384423/Belkin-PRO-Series-USB-Extension-Cable-4-8M/Product.html?searchtype=allproducts&searchsource=0&searchstring=USB+Extension&urlrefer=search
