Home Forums Printing Discussions Roland Printers I’ve got an ink line that wont fill up
  • I’ve got an ink line that wont fill up
    Posted by Mark A Brown on 12 April 2016 at 14:46
    Hi Guys,
    I’ve got an ink line that wont fill up. I’ve pulled through ink with a syringe and the ink flowed easily. The damper and new, the capping station is new. The other line that shares the same head is filling just fine. I just can’t get in in this one ink line. I’m stumped. Been at it all day and I still think its something really stupid and small that I’m missing.
    Has anyone else had this problem?
    From Mark
    Kevin Flowers replied 9 years, 8 months ago 5 Members · 6 Replies
  • Kevin Flowers
    12 April 2016 at 19:49
    what machine, sounds like manifold nipple may be cracked
  • David Rogers
    12 April 2016 at 22:13
    quote Kevin Flowers:
    Agreed, quite easy to do when changing the damper and a) manifold is a few years old and b) it was pulled off / pushed on not 100% straight.
    If it is, it’s a pain in the ass to change…most people resort to an engineer as it’s a head out and taking it to bits job with realignment afterwards.
  • Stafford Cox
    13 April 2016 at 08:27
    I’ll third that. It would be good to know what printer it is though.
    Stafford
  • Dan Osterbery
    13 April 2016 at 12:35
    have you also made sure the nuts above the dampers are done up tight? NOT massive force but must be tight to maintain the seal? goodluck
    Dan
  • Mark A Brown
    13 April 2016 at 16:11
    Hi Guys,
    I have a Roland Soljet Pro2.
    Its not big job replacing a manifold on a head, its really easy. Done it a few times now. I have a manifold in stock so I’ll replace that first.
    Thanks for you input.
    From Mark
  • Kevin Flowers
    13 April 2016 at 18:21
    Think i would be confirming it with a vacuum check to know I was curing the correct fault
