Home Forums Sign Making Discussions Buy – Sell – Employment I need a vinyl cutter from the range of 24" and up
  • I need a vinyl cutter from the range of 24" and up
    Posted by Petros on 16 May 2004 at 09:54
    Hey,
    Im new in the bussiness and i need a larger vinyl cutter.
    I have one Roland STIKA SX15 cutter that i would sell if i find a used or new cutter from 24″ and up.Tell me what you have plz
    Petros
    Petros replied 21 years, 8 months ago 3 Members · 4 Replies
  • David White
    16 May 2004 at 11:13
    I use a PNC1410 and have had trouble free use for5 years
  • Petros
    16 May 2004 at 11:52
    I saw the Ultra Pro Panther Cutter and i think is the best in the market.It has the followings specs:
    Acceeptable Material Thcikness: 50mil
    Drive Type: DC servo control motors
    Cutting Force: 10-600 grams down force
    Tangential Emulation Mode: Yes
    Cuttin Acceleration: 4.2g
    Maximum Cutting Speed: 60 inches per second
    Offset: 0-1.0mm
    Mechanical Resolution: 0.0125mm
    Software Resolution: 0.025mm
    Distance Accuracy: 0.254mm or 0.1% of move,whichever is greater
    Repeatability: 0.1mm
    Buffer Size: 4mb
    Interfaces: Parallel(Centronics),Serial(RS-232C),and USBAdaptor
    Commands: HP-GL,HP-GL/2
    Control Panel: 1LCM(2O digits x 2 lines or 14 digits x 4 lines), 1 LED AND 14 control keys
    Power Supply: AC 100-240V, 50-60Hz
    Power Consumption: Max. 11o Watts
    Pouncing Function: With optional tool
    Warranty: 3 years
    Some of the feathers:
    50 Foot Tracking
    60 ips speed
    600 grams downforce
    Media Basket
    Media Handling system
    DYNA-Flow media rollers
    Set-up nd training CD
    Includes stand
  • F. Skierk
    16 May 2004 at 21:07
    from past comments made here on this site graphtec seems to be a high choice. 🙄
  • Petros
    17 May 2004 at 03:51
    Ok do you have any cutter to sell ?
