Home Forums Sign Making Discussions Vinyl I need a source for Static Cling Window Film. can you help?
  • I need a source for Static Cling Window Film. can you help?
    Posted by red dragon on 27 April 2002 at 20:15
    Could someone recommend a source for the above, I’m only looking for smallish quantity (around 5 -10 mtrs). Also has anyone tried this on Brians favourite machine ๐Ÿ˜† (Roland PC60) then used the white ribbon for back printing?
    Many Thanks
    Sharon
    Robert Lambie replied 23 years, 6 months ago 8 Members · 14 Replies
  • 14 Replies
  • Brian Hays
    27 April 2002 at 20:23
    Arghhhhh the dreaded pc60. Last time I used one of their white ribbons you could just rub what it printed off. Dunno if they have improved any since then.
  • Lorraine Buchan
    27 April 2002 at 21:04
  • Graham.Scanlan
    28 April 2002 at 14:03
    is this what you are looking for,
    http://www.molco.com/epenstfa.htm
    however i dont know of anyone stocking it in the uk,
    Molco are our supplier of static film, if you speak to your local Europoint branch, they may order you a full roll with one of their shipping orders
    29 April 2002 at 13:14
    I bought a roll from Cox Plastics, 50mtr roll at 1000mm wide, dont know if they still stock it as this was a special offer. Dont know your local Branch but the Scottish branch is 01236 617771. They should be able to tell you if they stock it and your local depot.
  • red dragon
    29 April 2002 at 15:49
    Thanks all for the help. Will look into suggestions. It’s great being able to enquire instead of spending precious time surfing and getting nowhere.
    Sharon
  • Graham.Scanlan
    6 May 2002 at 18:14
    did you know that….
    standard window stick (screenprinting grade) is available from lots of stockist (Europoint included)
    on the roll both 1000mm wide and 1220mm wide (clear only)
    or in sheet form
    1000 x 700
    1220 x 914
    100 x 1550
    610 x 914
    all mm ๐Ÿ™‚
    sign making grade is another story
    6 May 2002 at 22:08
    Moonbrat whats the difference between the two?
  • Lorraine Buchan
    7 May 2002 at 15:13
  • Graham.Scanlan
    7 May 2002 at 18:25
    the difference between the printing grade of window stick and the signmaking grades are to my knowledge as follows
    sign grade
    is available in more than 20 opaque and translucent original colours and Film thickness: 150 micron
    Backsheet: 180 grs/sqm
    screen grade
    is available in white and clear, Standard thickness: 100 ยตm – 300 ยตm (Special: up to 1 mm)
    and the surface is treated so it can be offset,flexo or screen printed.
    I also think that the backing sheets are different between the two products
    7 May 2002 at 21:39
    do spandex not call that clear toilet roll lorraine? ๐Ÿ˜† ๐Ÿ˜†
  • Lorraine Buchan
    7 May 2002 at 22:03
  • Jodie
    8 May 2002 at 17:03
    I am nearly sure Hexis sell it by the mtr @ 610mm wide but only clear.
    http://www.hexis.co.uk. Brian ๐Ÿ˜€
  • Andrew Blackett
    10 May 2002 at 19:39
    Have a look at http://www.victory-design.co.uk
    they sell it on a 1m roll which you can get slit down to whatever size you need. I run it through our pc-600 and it always comes out perfectly.
    ANDY
    11 May 2002 at 07:01
    nice one andy. just realised the new face on the boards.
    welcome mate
