Home Forums Sign Making Discussions Neon, LED, Lighting i have a problem with LED lighting help please?
  • i have a problem with LED lighting help please?
    Posted by pilot on 28 November 2006 at 13:59
    we have produced a illuminated letters, the source of light are Gelcore PowerWhite LEDs. The letters are mad from aluminium, the front is made from blue acrylic. The depth of the letters is about 5 inches. Now we have a big problem: the illumination is not smooth and every one LED is visible through the blue acrylic, when powered. LEDs are mounted properly, everything works just fine, but the look is not that good because of the visibility of LED.
    To fix it, we have tried this, whit no succes:
    – additional coating (blue) on the front of arcylic,
    – additional coating (blue and white) on the rear of acrylic,
    – reflective sheeting over the LED.
    Please see the foto.
    Have anyone an idea, how to fix it?
    [/img]
    pilot replied 19 years ago 3 Members · 3 Replies
  • John Lyons
    3 December 2006 at 20:02
    BLANK
  • George Kern
    3 December 2006 at 21:56
    have you tried diffusing the letters more? diffuser vinyl, sanding the inside of the acrylic smooth so you cannot see through clearly.
  • pilot
    15 December 2006 at 08:33
    quote George Kern:
    Hi George,
    thank you for the hint. The blue acrylic is not transparent, I mean, there is nothing visible through it – it is just blue opaque acrylic. That´s the reason why I was that confused about this problem – we have made letters that way whit no problem like that, but we used different colors of acrylic. Only with this blue we had a lot of trouble…
    Now we have finally fixed it – with 4 mm thickness white opaque acrylics mounted from inside behind of the blue acrylic. It works, the lighting is smooth.
    But your idea sounds great. I will give them a try. When yhis works, it is a much cheaper methode.
    Thank you and have a nice day.
