Home Forums Sign Making Discussions Vinyl i have a mactac frosted vinyl problem?
  • i have a mactac frosted vinyl problem?
    Posted by Richard Urquhart on 6 July 2005 at 20:24
    hi all
    I’m faced with a new one
    i need to apply the above to 4 sets of windows easy you may say
    well thing is i had to buy 1220 wide vinyl as 2 of the windows are about that width the other 2 are smaller.
    I was going to cut vinyl to size on plotter but being only 610 wide i cant so I’m asking how would you do it
    i was thinking cut it about right size by hand and trim on the glass ,i will be using application fluid (sorry rob) and I’m worried that when i come to edges there going to be wet and wont stick to glass until trimmed to the correct size and i cant trim to correct size until edges are stuck to glass am i making sense
    any help
    rich
    Richard Urquhart replied 20 years, 4 months ago 6 Members · 6 Replies
    6 July 2005 at 20:40
    If you apply it wet it can be a pain to trim,
    cut it to the size on site -2or 3 mm before aplication, you can still do his on the window, just mark it and cut with a straight edge before removing the backing
  • Stephen Ingham
    6 July 2005 at 20:42
    hiya rich, we did some recently at a new Wilkinson store
    we were asked to apply frosting to external facing windows, we measured the windows and then cut the vinyl (by hand) approx 2in too big, applied to window (wet, sorry rob) squeegied water out then trimmed around perimetre of window, leaving approx 5mm clearance from edge.
    the windows we did were about 15ft x 3ft and we did 9 of them
    pretty easy job really, massive amount of static when we removed the backing paper.
    hope this helps
    stephen
  • John Harding
    6 July 2005 at 20:48
    Hi Rich as steven sais – shouldnt be a pain have done similar myself single handed, but its a struggle, if you have help its easier, did mine wet too sorry rob!
    Can give you a hand next week if there no rush
    6 July 2005 at 21:36
    awhh..what a nice bloke you are john 😀 great to hear folk onboard helping one another 😉
  • Andy Gorman
    6 July 2005 at 21:49
    If you know the sizes you need, why not just cut to exact size on the bench? Shouldn’t be a problem as long as the windows are nice and square. As has been mentioned before, I think a full flood coat of etch/frosted looks smartlier (real word!) with a small clear border around.
  • Richard Urquhart
    6 July 2005 at 22:05
    wow i would be lost with out this site thanks all and john thanks for the offer i will give you a shot if i need some help its very nice of you to offer i think when we spoke your not far from me
    i think i may take big gs advice and cut to size on bench sounds like a good idea and the wingdows are d/glazed in ali frame and look 100% so should be ok i will let you know the out come
    big thanks once again
    rich
