Home Forums Printing Discussions Mimaki Printers I have a CJV130 with the following problem just after any idea what it could be?
  • I have a CJV130 with the following problem just after any idea what it could be?
    Posted by Richard Thompson on 4 September 2018 at 16:57
    Hi Everybody
    I have a CJV130 with the following problem just after any idea what it could be:
    1. On a test print banks of magenta and some banks of cyan are missing? when i do a " Fill up Tank" in maintenance
    an redo the test print the missing banks on colour come back.
    2. also have noticed if i was to print an image it is showing a type of magenta "overspray" on the left edge as you look at the print.
    any ideas anybody?
    Many Thanks
    Richard
    Stafford Cox replied 7 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Iain Pearson
    4 September 2018 at 17:27
    Stafford Cox is your man to speak to.
    I have same machine but never had that problem, sorry
  • Kevin Flowers
    4 September 2018 at 17:32
    How old is the machine, my 1st point of call would be to change the dampers & capping station
  • Richard Thompson
    4 September 2018 at 22:21
    Hi Kev
    The machine is about 9 year old, had new printhead fitted by Hybrid a 3 years ago, in the time I’ve had it it not been heavily used, but cleaned regularly.
    I myself thought it could be the dampers or pump? the problem its very odd, I can do test print one minute and all seems to be ok, then after doing a print job if i carry out a test print it shows large sections of colour banks missing??
    I’m going to order 8 new dampers tomorrow and a pump to see if that cures it?
    I’m still open to any other ideas that anybody has to what the problem could be?
    Many thanks.
    Richard
  • Kevin Flowers
    5 September 2018 at 10:58
    I would say damper, but on that age machine i would treat it to new dampers & camping station, bad seal on capping station would show up as a pump issue
  • Richard Thompson
    5 September 2018 at 11:23
    Hi Kev,
    Thanks for the reply,
    I replaced the the capping station few weeks back with no noticeable change, I will replace all the dampers this week and pump and ill see if it cures the issue?
    Richard
  • Kevin Flowers
    5 September 2018 at 11:25
    without teaching you to suck eggs did you ensure it was sealing & id you have the issue before or has it occurred afterthe swap
  • Stafford Cox
    5 September 2018 at 13:17
    Hi Richard.
    I’d go with dampers first, too. The fact you can get the nozzle test back from cleaning would suggest to me that the pump and cap are doing their job. I only use/sell genuine compression dampers on these machines as generic ones have proven temperamental in my experience. Just replace the ones that need replacing though.
    As for overspray, it could be anything. Pictures say a thousand words in these situations. Post some up and I’ll see if I can help.
    Stafford
