Home Forums Printing Discussions HP Printers HP Latex Printer status: Offline, help please?
  • HP Latex Printer status: Offline, help please?
    Posted by Stephen Benson on 20 February 2020 at 16:27
    Hi all
    I wonder if you can help, our HP latex 360 shows in its status that it is "Off-line".
    Does anyone know how I get it back Online?
    Thanks in advance for any help.
    David Wilde replied 5 years, 10 months ago 3 Members · 4 Replies
  • Colin Crabb
    20 February 2020 at 17:55
    Onyx RIP? if so press the red icon, to turn it green as below
    20 February 2020 at 22:55
    Colin is most likely correct here… :thumbsup:
    another issue may be that the IP address has bee changed. but try Colin’s suggestion first as its quick and easy done.
  • Colin Crabb
    21 February 2020 at 12:24
    quote :
    Onyx (should) warn you of this with a warning pop-up screen.
    Have you fixed the issue?
  • David Wilde
    21 February 2020 at 12:50
    We’ve had this a couple of time. Usually a network issue, complete reboot over everything often does the trick. However last time it was down to a windows update messing with the assigned IPs as previously said this is probably the issue
