Home Forums Printing Discussions HP Printers HP L26500 fault
  • HP L26500 fault
    Posted by Hugh Potter on 28 February 2018 at 10:59
    Following a series of 10+ power cuts this morning my printer is telling me to close the right door, it is closed, any idea how to fix / clear this?
    Have tried turning off from the front panel but it just sat in cooling mode for 15mins..
    Help!!
    Hugh Potter replied 7 years, 10 months ago 2 Members · 3 Replies
    28 February 2018 at 11:34
    Gets worserer…
  • Myles Brewer
    28 February 2018 at 12:45
    quote Hugh Potter:
    Help!!
    Hi Hugh. ohhh!! sounds bad 🙁 Presuming you’re getting hit by "The Beast"?? Sun shining here in the North West of Ireland remarkably & I hear Dublin is under a bit of the white stuff ha ha!! Makes a nice change :smiles:
    Sorry, I can only suggest unplugging it until the danger passes. I did have a similar issue a while back re stuck in cooling mode & ended up switching off from the back & removing plugs. The next time it fired up ok & haven’t had any issue since, but I always switch off from behind & remove plugs if there is a chance of power outage or surge to be safe.
    28 February 2018 at 12:55
    Massive thanks to the Perfect Colours engineer who called just now..
    The main fault was cured by pressing the little reset button on the control panel, then I just had to take the end off and sort the door switch out, unsure what was causing it but it works again now, I can breathe a sign of relief now, especially as I’ve just bought a new space heater and can finish wrapping the car I’ve had since Monday!!
