Home Forums Printing Discussions HP Printers HP Designjet Printer T770 – advice needed, please?
  • HP Designjet Printer T770 – advice needed, please?
    Posted by Harry Cleary on 21 August 2015 at 11:19
    I wonder does anybody know the answer to this. Does this printer perform the same as the HP 5500 series printers? Thanks
    Harry Cleary replied 10 years, 2 months ago 2 Members · 4 Replies
  • Doug Hing
    21 August 2015 at 15:52
    Hi Harry,
    The Designjet 5500 printer was a "higher volume" graphics printer which is why the cartridges have a a capacity of 775ml.
    Technology has moved on and the Designjet T770 printer is geared more to lower volume printing (130ml ink capacity). You will be able to achieve high quality prints but depending on your current output it could become quite expensive to run in comparison to the current replacements for your 5500.
    the HP Designjet 5500 was superceded by the Z6100, Z6200 and the current models are the Z6600 and Z6800 both 60" printers.
    (the Z6200 still comes in 42")
    these are the models you need to investigate if you are looking for a direct replacement for the 5500.
    regards
    Doug Hing
  • Harry Cleary
    21 August 2015 at 18:29
    Thanks Doug. Does it print to the same media types as the 5500?
    Primarily I want this for indoor posters but the ability to print occaisional banners and adhesive vinyl would be nice.
  • Doug Hing
    24 August 2015 at 13:01
    In terms of the ink type, the new Vivera inks will print on to the materials suitable for the Designjet 5500 with UV inks.
    Most of the inkjet media out there now would be compatible.
  • Harry Cleary
    24 August 2015 at 22:01
    Thanks Doug, appreciated.
