Home Forums Sign Making Discussions General Sign Topics How would you cure vinyl which is peeling from a window??
  • How would you cure vinyl which is peeling from a window??
    Posted by Soyeb Ravat on 28 May 2009 at 13:51
    How would you cure vinyl which is peeling from a window when you have just put the vinyl on???
    imagine a triangle being stuck on a window and the point at the top is not stuck on properly. how can i cure this??????
    is there special solution i can get??
    although its the tip only i have the problem with and the adhesion on the rest of the triangle is fine i fear sooner or later it may become bad to worst and peel more so.
    please help!!! and thanx in advane!!! 🙂
    Soyeb Ravat replied 16 years, 7 months ago 7 Members · 12 Replies
  • 12 Replies
    28 May 2009 at 13:56
    hi dont make it such a sharp point, if your steady with the blade slice a bit of each side of the triangle, that should help 😀
  • Soyeb Ravat
    28 May 2009 at 14:01
    thanks nic!! will definately adjust
  • Chris Windebank
    28 May 2009 at 14:10
    did you apply wet?
  • Soyeb Ravat
    28 May 2009 at 14:25
    Hi Nic,
    yes the vinyls were applied wet.
  • Soyeb Ravat
    sorry i meant chris.
  • Gary Birch
    28 May 2009 at 15:16
    I think you’ll find that is where the problem lies, apply dry and try it.
    Gary
  • Soyeb Ravat
    28 May 2009 at 15:21
    thanks gary will try!!
    28 May 2009 at 17:27
    Try gently heating it – e.g with a hairdryer – this may help
  • Mike Grant
    28 May 2009 at 21:04
    Did you thoroughly clean the glass. If there was just the slightest bit of grease left you will have a problem. Sharp points on glass will be a problem the first time someone tries to clean the window with a fluffy duster.
    You will also find that the adhesive area is so small at the tip of the point just the slightest bit of dust under it will stop it from sticking. Definitely apply dry if you can.
  • Soyeb Ravat
    1 June 2009 at 14:46
    I have also heard from a friend that using clear nail varnish seals and secures delicate areas. Would anyone know anything about this?? is there a special solution available specifically for delicate areas??
    cheers in advance!! 🙂
  • BrianGreen
    2 June 2009 at 16:28
    you may find that the vinyl was rolled the wrong way which makes it pull away i have had this problem before as Phill said try applying heat with an hair dryer it as always worked for me hope this is of some help
  • Soyeb Ravat
    2 June 2009 at 16:35
    thanks brian will give it a shot!!
