Home Forums Sign Making Discussions CNC Router and Engraving how to use a router help and advice
  • how to use a router help and advice
    Posted by John McCrorie on 13 March 2010 at 18:55
    I have just purchased a cheap router and router table, I’m hoping to make small wooden sign blanks and plaques etc. I have never used a router before so I’m looking for some help and advice & tips on using it. I’m hoping to use it to make sign blanks, engrave letters & templates etc, any books or courses you would recommend.
    Thanks for any advice
    Adrian Ayre replied 15 years, 9 months ago 4 Members · 5 Replies
  • Ian Johnston
    13 March 2010 at 19:01
    youtube, will have everything you want to know
  • Kevin Parr
    13 March 2010 at 19:32
    Yep Youtube all the help you need all you have to put in is imagination
    13 March 2010 at 23:57
    well not sure how we can help you…
    each router is a little bit different to the other….
    if cutting metals, make sure you have mist of coolant !! 1 tip for you.
  • Ian Johnston
    14 March 2010 at 10:17
    quote Dave Rowland:
    he’s talking about a hand held router Dave
  • Adrian Ayre
    24 March 2010 at 09:13
    As mentioned above if you’re cutting metals use a coolant if your machine doesn’t have coolant unit then the every useful trigger spray will do the job.
    If you’re cutting wood make its well seasoned, Oak especially can be a nightmare in terms of splintering if its remotely green
    you’ll need to experiment a little with feed rates and spindle speed to find the best combinations for your machine on different substrates.
    Stainless steel especially requires slow feed rates and multiple passes if you’re going to achieve crisp engraved text deep enough to paint fill
    Adrian
