Home Forums Sign Making Discussions Neon, LED, Lighting how to stop seeing joints on a lightbox panel?
  • how to stop seeing joints on a lightbox panel?
    Posted by Stephen Ingham on 27 March 2007 at 19:37
    Hi all, just a quick question, am sure this has probably been asked before, but here goes..
    i have a 30ft lightbox to fit soon which is obviously gunna have a number of joints in the facia panel.
    my question is how do i diguise them, keep them together and not cast a shadow on the joint??
    any help appreciated
    stephen
    Nik replied 18 years, 6 months ago 4 Members · 5 Replies
    27 March 2007 at 20:12
    Flexface? or does it have to be pex?
    If perspex, a rebate join is usually fine, use panalocks to hold them together
  • Stephen Ingham
    27 March 2007 at 20:18
    hi peter, perspex/ acrylic
    done rebate before on a smaller box, wot are the panlocks? and where do i get them?
    27 March 2007 at 20:23
    SMP on supliers index
  • Kevin Flowers
    27 March 2007 at 21:59
    if you are fitting a new box have them supply the perspex that way it will have hanging strip & rebates all done for you, can work out better cost wise as well depending on the size.
  • Nik
    27 May 2007 at 12:18
    I’m guessing that the panels are perspex and the whole sign is illuminated. A simple panel lock top and bottom would keep the panels together. A panel lock is basically two pieces of material with a hook at one end and they interlock.
