Home Forums Sign Making Discussions Neon, LED, Lighting how to securely fix a 8×4 sheet of dibond to a wire mesh?
  • how to securely fix a 8×4 sheet of dibond to a wire mesh?
    Posted by Deleted User on 9 December 2005 at 09:14
    Hi everyone,
    Do any of you have any ideas on how to securely fix one 8×4 sheet of dibond to a wire mesh fence? Is there any kind of fixings we could use?
    Deleted User replied 19 years, 11 months ago 6 Members · 11 Replies
  • 11 Replies
    9 December 2005 at 09:22
    Large cable ties from srewfix?
  • Nick Minall
    9 December 2005 at 09:32
    Yes cable ties and you can get them in colours if you need to try and hide them.
  • Paul Rollason
    9 December 2005 at 09:44
    If you want something a little more robust try these
    http://www.cse-distributors.co.uk/cabmg … e-ties.htm
    paul r
  • Deleted User
    Deleted User
    9 December 2005 at 09:57
    Will these be strong enough? Is there no fixings that will clamp the panel to the fence?
  • Nick Minall
    9 December 2005 at 10:01
    Well you could nut and bolt it and fit big washers on the back or make some plates from Di-bond
  • Dave Bruce
    9 December 2005 at 12:21
    Better going for the channel, as in road signs and bolt to another strip on the otherside of the fence, neat and professional.
  • Carrie Brown
    9 December 2005 at 12:26
    We would do it and have done it the way Dave has suggested. Strip on the other side of the fence. It gives a nice neat professional finish.
  • Nick Minall
    9 December 2005 at 12:31
    Dave’s way is the best, it will also help to keep the Di-bond flat.
  • Deleted User
    Deleted User
    13 December 2005 at 11:56
    Hi again,
    When you say bolt the channel to another strip of channel on the other side, do you mean bolt using normal 76mm clips or just normal bolts or self drillers?
  • Dave Bruce
    13 December 2005 at 14:04
    David you get bolts with the clips normally when fastening to the poles, they are standard stainless ones, in your case just order then with the channel. The head of the bolt goes in the channel groove preventing it from turning.
  • Deleted User
    Deleted User
    13 December 2005 at 14:17
    Yes, I have some here, we use them with galvanised poles. Do you think it would work just threading the clips through the fence, without a pole, maybe putting a little 70mm strip of dibond in behind it?
