Home Forums Sign Making Discussions Vehicle Wrapping How to remove the door handles on a renault master?
  • How to remove the door handles on a renault master?
    Posted by Bart Van Wassenhove on 23 April 2013 at 07:16
    Goodmorning everybody,
    we have to remove the front door handles on a renault master – for a perfect wrap 😉
    Anyone knows how to do this?
    Best regards,
    Bart
    Gavin MacMillan replied 11 years, 7 months ago 3 Members · 3 Replies
  • BAPrint
    23 April 2013 at 18:49
    Hi Bart. We have in at the mo a vauxhall movano 2013 model. Took a while to sus out
    But got there in the end. On the side of the door inline with the handle there is a black grommet. Pop of and you canput a flat screwdriver in and twist the lock holder round
    Towards the top of the door. You can then pull out the rear smaller part of the handle
    Once this is removed the main handle will slide back and release..
    Hope this helps
    Graham
  • Bart Van Wassenhove
    23 April 2013 at 19:13
    Hi Graham,
    thanks a lot for your reply. We also found it after a lot of Sherlock-work 😉
    Keep up the good work!
    Cheers,
    Bart
  • Gavin MacMillan
    13 March 2014 at 19:14
    Just found this, we’re wrapping a master just now as well. Removed the handles but for some reason struggling with the drivers door?
    Also, I left the barrels in place , after seeing the mechanism on the rear door I figured it may be hard to put back together if I take it right out, trouble is I can’t get the handle back together without removing this completely, any tips on reassembly?
    Thanks for any help
    G
