Home › Forums › Sign Making Discussions › Vinyl › How to: pattern logo on large wall – help please?
Posted by Tim de Beir on 30 November 2015 at 22:21I have to apply a pattern from the clients logo (and It was my idea to turn it a few degrees) Wall is approx. 3,5m width x 5m height.
See attachment, how would you guys do this?
Chris Rogers replied 9 years, 11 months ago 6 Members · 12 Replies -
hi derek that looks great what fabric did u use to print on, cheers
Tim
You didnt say if it was an internal or external wall.Simon.
Nice work Derek! Looks good.
Not seen you on here for a while!
Hiya Derek, hope you’re well.
What is this fabric? is it self adhesive or pasted or what? We also hate joins so this is interesting.
Warren
Paint the wall and use cut vinyl 😛 😉
quote Tim de Beir:I have to apply a pattern from the clients logo (and It was my idea to turn it a few degrees) Wall is approx. 3,5m width x 5m height.See attachment, how would you guys do this?
hi Warren
the system we use for internal is called fabtrack can also be used on curved walls and ceilings
think at the moment it can go up to 5 metres high without a join
can be either dye sub or uvand external we use crystal
have a look at fabtrack.co.uk for some more pics and infoFabtrack is a plastic extrusion that is designed to tension fabric with zero finishing requirements. No stitching, No silicon, No keder.Fabtrack can tension fabrics from 200g/m up to 300g/m, from printed fabrics, to textured fabrics.
Derek
quote Derek Heron:hi Warren
Derek
Thanks Derek, will take a look.
We’ve done a couple of walls with wallpaper stock (let it dry off for a couple of days before you apply), looks good if you can live with joins. Alternatively you could print onto vinyl and get a textured laminate.
