How to fit built ups with LED’s to a wall. Wire routing prob
Hi all.
Am currently quoting for a job that requires Built up metal letters with LED’s to be fitted to a brick pier. What I can’t work out, is where the wires will go from the LED’s. As you know, on a normal sign, you feed the wire down by the locator & join it all up at the rear of the substrate, but as this is a brick wall, this will be unachievable won’t it? I don’t want the wires running along the brickwork, but at the moment, this is looking like the only way isn’t it? I’ve no idea how thick the wall is & what it backs onto, as I’ve not seen the site yet, just phone conversations so far.
Has anyone fitted direct to brickwork before, & if so, how did you overcome this problem?
Many thanks!
Gwaredd.
