Home Forums Sign Making Discussions General Sign Topics How to fit a sign onto an exterior insulation wall?
  • How to fit a sign onto an exterior insulation wall?
    Posted by Mohammad Esa on 29 July 2017 at 12:39
    Hi everyone,
    A customer has requested a sign 210 x 212 cm, so we have cut 2 sheets of dibond in 210 x 106cm. My problem is that the exterior wall of his shop has this new insulation (Polystyrene) fitted, and I don’t know what the best way to fit it. Approximately 2 metres of the ground
    Thanks in advance
    Stephen Morriss replied 8 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Andrew O Brien
    29 July 2017 at 13:39
    Long screws and bond it to the wall?
    29 July 2017 at 15:37
    Are you saying the face of the wall/building is actually the insulation?
    Normally you will have a face panel, then insulation. This can be 1mm thick steel or even composite etc etc.
  • Andrew O Brien
    29 July 2017 at 15:42
    They normally just put a special render applied over the insulation. Normally the insulation is around 100mm then the render. It would support nothing.
  • Iain Pearson
    29 July 2017 at 16:52
    Did you do a site survey before agreeing to undertake the work ?
    Is there any other location the sign could go
    29 July 2017 at 19:55
    quote Andrew O Brien:
    OK, got you now… and understand what you meant by long screws and liquid bonding.
    Thing is, the screws are put in blind and depends what they hit to make a good fixing. The liquid bonding would obviously hold once set, but if the sign has to be removed, i would expect that to pull the render from the insulation.
    What about using a wall masonry wrap?
    just apply the prints directly to the wall with zero fixings.
  • Mohammad Esa
    1 August 2017 at 21:08
    quote Iain Pearson:
    I did a site survey, and I recommended a different location as being the best place to put the sign up, but they didn’t take my recommendation and was certain they wanted it on the insulation. :bangshead:
  • Iain Pearson
    1 August 2017 at 21:14
    I think then I would consider Robs comments and possibly suggest to the client you apply a printed vinyl direct to the substrate
  • Stephen Morriss
    2 August 2017 at 12:10
    Bit late but you needed to specify that you will not fit to the insulated wall or if you do you take no responsibility for any subsequent damage or leaks, even then you’d be better doing some research on specific wall fixings.
    Or look into Robs suggestion.
