Home › Forums › Sign Making Discussions › General Sign Topics › How to do a curved sign tray?
Posted by Erdy Cem on 7 March 2024 at 16:48Hi Guys,
I’ve got a job to do a 26m long composite sign tray with 80 x 3d letters on. However 3/4 of the building is round, so about 17m-18m of the sign tray must be curved.
Any idea how we can do the trays, and how I can do the rails for fixing? We’ve never done a curved sign tray that size.
I appreciate your advices if you can share your experiences. Thanks all.
Erdy Cem replied 1 year, 9 months ago 3 Members · 10 Replies -
Hi Erdy, Have a look at page 17 in this guide. It shows how to create a curve using Dibond. There’s a ton of other information in there too. Hopefully it’ll help you out 🙂
Hi Erdy
Not something I have had to do myself, in-house, But I would think you would need to use aluminium or stainless steel and not Composite.
The initial problem is finding an accurate radius and if it’s not a true circle, then working out the curvature.
Let’s assume the curve is on the corner of a street building.
You can see by starting with a box set at the length and width of the building.
Then insertting a circle to show the curved corner.Click the images to enlarge.
Scroll left and right to browse through them. -
from here on, you would create the flat pans for either side of the curve.
once you have formed the entire pan, flat areas and curve, you then have to create an internal one.
the internal one will hold all your wiring, drivers and all else. which should be fitted first, then the face of the sign fixed to the internal pan.once all the welding, drilling, sealing, cleaning and surfacing preperation is done, you can then paint or powder coat.
The last thing you need to take into account is…
You mentioned 3D built-up letters.
you must take into consideration that if mounted on stand-off fixing points, the curve might prohibit this from working, depending on how tight the curve is.
I remember a while back, I was fitting cuved letters to a curved wall and this issue reared its head.
in short, I had to roll the circular logo into the curve of the wall to allow the raised sign/letters/logo concept to work.Not easy, and not cheap to fix, but it was a lack of experience in this aspect of sign-making on my part, back then, and by the time I corrected my mistake, the sign was running at a loss.
Thank you very much for all valuable information. I appreciate that.
