Home Forums Software Discussions Adobe Software how to divide the photo and change resolution to print?
  • how to divide the photo and change resolution to print?
    Posted by Lynn Wang on 12 July 2013 at 20:50
    hi
    i will print wall paper covering around 2×3 M as its size , will divide 3 or 4 section , overlapping 1 cm
    the photo size is
    30 cmx28 cm (300dpi) 34.5 MB
    how to cut into 3 or 4 sections and change size and resolution in photoshop?
    thanks
    David Rogers replied 12 years, 5 months ago 5 Members · 5 Replies
    13 July 2013 at 08:02
    What RIP software do you have with your printer? Easiest way is to let the RIP software tile it (slit it into sections). Photshop will crop & resize it for you easy enough then just output to RIP, tile & print.
  • John Thomson
    13 July 2013 at 09:54
    I agree with Martin…….let the rip software do the work and tile it… just remember to set your overlap to 10mm if that is what you want.
    13 July 2013 at 11:09
    you need to get the base proportion right first as you are trying to fit a square in to a oblong. once you have a image to fit the wall space then you can tell the rip where to pannel it.
  • Lynn Wang
    13 July 2013 at 11:43
    HI
    thanks for the answer , i have versaworks.
    i will do in the rip
    how i know the photo is good enough to print after change size and resolution in photoshop ?
    or is there way to change the photo in the rip?
    thanks
  • David Rogers
    13 July 2013 at 17:14
    quote lynn wang:
    HI
    thanks
    Crop a section and print it….
