Home Forums Software Discussions Adobe Software How to disable isolated group in adobe illustrator CS2
  • John Childs
    6 November 2007 at 10:14
    I’m not quite sure what you mean Russell, but it sounds like you might not be using the appropriate selection tool.
    Try playing with them.
  • Russell Pavey
    6 November 2007 at 10:21
    Morning John
    Thanks for taking the time to reply again!
    I mean the little grey box that appears around a group of objects when you double (or triple click by accident) click on an object. You then have to right click and select exit isolated group before continuing.
    Am just using the main selection tool as I always do.
    Trust me I have had a play and Goggled it without joy and thought someone on here may have had the same problem in the past.
  • Jamie Wood
    6 November 2007 at 13:08
    If you double click it again, it should de-select it. It does in CS2 and CS3.
    Cheers,
    Jamie
