Home Forums Software Discussions Corel Software how to create this border around wording??
  • how to create this border around wording??
    Posted by Nick Minnery on 25 February 2016 at 12:59
    Hi guys
    No doubt I’m gonna sound a bit of a thicko here, but how would I add a surround- in Coreldraw- to some words, like the black part in the attached image?
    Thanks in advance
    Nick
    David Mitchell replied 9 years, 9 months ago 7 Members · 7 Replies
  • 7 Replies
    25 February 2016 at 13:09
    on your tool bar..
    effects> contour, it will put the contour box up and you can play with internal & external contours.
    H
    I dont use corel…
    but in signlab i would just apply a heavy outline around the text, then the flag, then weld it.
    in photoshop do it using "stroke"
    there will be some white spaces appear but use fill them before welding.
  • Ian Jenkin
    25 February 2016 at 13:26
    Hi Nick, create a contour – then break it apart from the text.
    Then on the contour only – break curve apart and remove the middle parts.
  • Nick Minnery
    25 February 2016 at 15:31
    Many thanks Hugh, Rob, Ian – great help, sorted now :thumbup2:
  • Harry Cleary
    25 February 2016 at 17:32
    oops…read post wrong. 😳
    2 April 2016 at 16:24
    Use the interactive contour option you can drag to the size you want and later versions allow different corner styles
  • David Mitchell
    3 April 2016 at 08:53
    contour then to remove the little but, Araange > Shaping > boundary, gives outline, delete the rest
