Home Forums Software Discussions Adobe Software how to convert an illustrator path to cut line in Versaworks
  • how to convert an illustrator path to cut line in Versaworks
    Posted by Christina Vines on 15 July 2008 at 20:06
    Really struggling here….
    Trying to convert an illustrator path to a cut line in Versaworks. Maybe you can see where I am going wrong.
    I have created a solid path in illy CS3.
    I have coloured it using my CutContour spot colour in illy.
    I have saved the file as an EPS 3,4,5,6, to CS3 and as a PDF but still Versa fails to see that there is a cut line.
    I have been searching high and low on-line for the answer. It’s probably staring me right in the face…
    All thoughts most welcome and appreciated.
    Thanks guys
    Christina Vines replied 17 years, 5 months ago 7 Members · 9 Replies
  • 9 Replies
  • Frank Horner
    15 July 2008 at 20:32
    I don’t work from Illustrator much, but all I can suggest is check the thickness of your cut path, too thick the rip does not process it. the other thing to check is that you have the process cut path turned on in the rip.
    Frank
  • Nick Dowell
    16 July 2008 at 08:12
    I think Frank is right, I believe it will only work with a 0.25 stroke line, with the CutPath being the stroke colour. Also the colour set for the cut line needs to be named "CutPath" – capital "C" capital "P" with no spaces.
    Stupid system if you ask me!!!!
    Anouther alternative is I can send you a working file with a cut line on which you can just copy on to your file?
    Nick
  • Richard Urquhart
    16 July 2008 at 08:37
    send me the file and I will put the cut line in for you for versa works
    rich
  • Scott.Evans
    16 July 2008 at 09:23
    i have a vesaworks plugin and that has a spot colour on that gets picked up in versa.
  • Nick Minall
    16 July 2008 at 09:32
    also make sure you have the EPS margin set to 1mm in Versaworks
    go to queue properties > file format > EPS margin, you need this to see the cut line in Vesaworks. and you need to send it as EPS 3
  • Scott.Evans
    16 July 2008 at 09:36
    sorry just read over your post and can see that you are using your spot colour. try setting your stroke line to 0.25 .
  • Nick Minall
    16 July 2008 at 09:43
    I have my outline set to 1pt works fine.
  • Kevin Flowers
    16 July 2008 at 11:04
    do you have a file margin set up in VersaWorks, if not double click on one of the folder on the VersaWorks main page go to File Format top of the page is EPS margin set that to 0.35 then save see if it cures your problem.
  • Christina Vines
    22 July 2008 at 16:54
    Thank you for responses, I set the stroke to 0.25 as suggested and cut the job today. Thanks again!!!! 😀
