Home Forums Sign Making Discussions Job Pricing How much per metre
  • How much per metre
    Posted by Ade Brown on 10 July 2009 at 18:32
    Hi All,
    how much would you charge per liner mtr of 610 3M 680 series reflective applied, based on purchase price approx £22.50?
    Ade
    Ade Brown replied 16 years, 5 months ago 2 Members · 5 Replies
  • Ade Brown
    11 July 2009 at 07:22
    someone, anyone?
  • David Rogers
    11 July 2009 at 09:19
    Cut, un-cut, text, chevrons, on flat panels, over recesses or on a sign board…a lot of variables all going to vary the price.
    Say you double it so you can make a reasonable markup on the product plus an application / cutting charge.
    DAve
  • Ade Brown
    11 July 2009 at 09:53
    Hi Dave,
    its all text on the side of Ambulances that require names changing from Blue reflectives to Green and all other county names etc doing in black!!
  • David Rogers
    11 July 2009 at 10:15
    Then unless it’s been pre-stripped you’re in for lots of fun…
    reflective can be a nightmare to get off if it didn’t have a backing to it.
    Not knowing the size / area per van – but I’d be pricing it per ambulance rather than just linear materials used.
    Material costs – say roughly double them and add on an estimated hourly rate per vehicle. Say £30/h or whatever you work at.
    If there is a strip involved – same hourly rate as there’s no materials.
    TOTAL guesswork as I haven’t seen either vehicles or know the layouts.
    Suppose it takes you 2 hours to strip & clean each one – £60
    Materials per vehicle – cost you £50 – sell around £100
    Application / cutting time – generous 1.25hrs as it doesn’t sound like a big job. – £45
  • Ade Brown
    11 July 2009 at 10:39
    hi Dave,,
    thanks for that!!
    I have alredy stripped afew that we being taken off road, some have been double applied..
    The ones I got to re-do will have clear vinyl under the reflective..
    Not a problem with rest of costing just wasnt to sure if £50 par liner applied was reasonable
    Ade
