Home Forums Sign Making Discussions Neon, LED, Lighting How many stand offs for this size acrylic panel
  • How many stand offs for this size acrylic panel
    Posted by John Parfit on 15 July 2011 at 03:58
    Good morning
    We have been approached by a customer who wants a quantity of wall signs in clear acrylic with chrome standoffs, print on rear, each 110cm x 25cm.
    We do not often have cause to manufacture these and the customer has specified each sign to have 4 standoffs, one in each corner.
    Does anyone with more experience think that long thin signs like these, even in 10mm acrylic would be better with 6 standoffs, we don’t want to follow the spec and end up with signs that ‘wobble in the middle but equally we don’t want to ‘over specify’
    Thanks in anticipation
    John Parfit replied 14 years, 5 months ago 4 Members · 6 Replies
  • Tim Painter
    15 July 2011 at 09:06
    Personally I would go with 6 at that size.
    You only need someone to lean on it or something.
  • Robert Kulawik
    16 July 2011 at 10:52
    Hi John,
    I definitely would advice the client that six is needed- it is very long for only edges support.
    Robert
  • Glenn Sharp
    16 July 2011 at 11:04
    I personally think you’d get away with 4 at that size….it’s a narrow display and if someone does lean on it it would only bend
    In the past we have used 25 mm Satin S/S standoffs with a couple of the snapfix Jumbo locators invisibly fitted in the middle just to stiffen displays up whilst not looking too industrial and keeping costs down
  • John Parfit
    16 July 2011 at 16:46
    Thanks for all your replies folks, 6 it is then, or I particularly like Glenn’s idea of one or two ‘invisible’ locators in the middle somewhere.
    Now all we’ve got to do is find a supplier of the acrylic rectangle, I suppose it’s too much faff to cut and drill them ourselves without a CNC or laser; all the flat cut letter companies are treating them as 110cm high letters so the price is coming out at between £50 -£70 pounds each, seems a bit excessive although I know 10mm acrylic isn’t cheap.
  • Tim Painter
    16 July 2011 at 17:14
  • John Parfit
    18 July 2011 at 10:47
    Thanks Tim, will certainly request a quote.
