Home Forums Sign Making Discussions Neon, LED, Lighting how do you cut/finish your corners on Dibond please?
  • how do you cut/finish your corners on Dibond please?
    Posted by P. Harris on 8 June 2007 at 08:36
    Hi, just after a bit of input on how you cut/finish your corners on Dibond
    Aluminum Composite Sheet. After i’ve routered out the folds i copy the
    Dibond sample i required with the triangle cut-out (not the simple cut-out
    the corner technique i’ve seen) this allows you to have any fixings
    that hold the corners to the bottom/top or sides and gives a stronger
    corner (i’ll attach a pic if your not sure of what i mean).
    Sorry to waffle, My Main Question is This-
    How can i produce/Cut Neat/Tight Fitting Corners.
    I’ve seen some DiBond Sheers Do They Work??
    At Present i Cut the Corners using a Mini Metal Saw Giving a
    Hand -Cut Gap of 1-2mm Roughly, I’m After a Cleaner Hard to See
    Finish. Hope me Description Helps.
    Cheers Brock
    Nick Minall replied 18 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Cheryl Tissington
    8 June 2007 at 09:07
    I finish the corners by cutting out with a stanley knife.
    It’s neat and with straight, sharp edges.
    Cheryl
  • Gavin MacMillan
    8 June 2007 at 09:14
    Hi Brock, the way you described was how we were shown and made our first trays. After a while though we changed and now make them as Cheryl described. Cutting a square out with a stanley knife puts the join right on the corner but it’s very neat so is not a problem.
    G
  • P. Harris
    8 June 2007 at 11:26
    Thanks for your replies, just cutting the corners out sounds great,
    a simple solution and stanley knife through the ali simple solution.
    But i prefer the corner i do now purely down to strength and if i could
    get a neater join it would be great. Its down to the fact my metal job
    saw is loosing about 1-2mm, has anyone tried out those Dibond metal
    cutting shears could they be my solution? anyone ever bought a pair?
    I can reflect a uksignboards member using air powered cutting shears??
    Do they work or do a clean/neat cut.
    Sorry to Pessta.
    Cheers Brock
  • Gavin MacMillan
    8 June 2007 at 11:40
    How are you fixing the corners? I don’t think strength is an issue and there are no forces of any kind put on the corners. Our decision to change was purely because they look better, I think that is the main issue.
    We glue pieces of angle into the corners by the way.
    G
  • Fred McLean
    8 June 2007 at 13:29
    isted of removing the mitre right on the corner(a square)
    move the mitre round to the top and remove a triangle
    When you come to form the box bend top/side and small flap and secure the flap and top with a small plate,no need for glue or anything 😀
    obviously same for other 3 corners.
    hope that makes sense 🙄
  • P. Harris
    8 June 2007 at 14:21
    Thanks again for all your in-put. I Rivit a small plate behind.
    I’m best postin some pics, easier to see.
    I’ll post monday, got to finish tray’s for fitting monday morn.
    Cheers Brock
    8 June 2007 at 14:54
    Picture here, of the corner brock describes
    http://www.uksignboards.com/viewtopic.p … ond+manual
    The shears from jag sign supplies are good, but a little expensive
    peter
  • Nick Minall
    8 June 2007 at 15:07
    Can you just use tin-snips?
