Home Forums Software Discussions Adobe Software how do you convert outlined illustrator text into vector?
  • how do you convert outlined illustrator text into vector?
    Posted by magpie on 20 November 2003 at 17:53
    Does anyone have a niffty technique for creating two cutable outlines from a line of illustrator
    text with a stroked outline?
    Alternatively is this something better done in freehand or some other software?
    magpie replied 22 years, 1 month ago 2 Members · 2 Replies
  • Tim Shaw
    20 November 2003 at 20:13
    Take a look in the select menu under paths, In here you will find two menu selctions called outline path and expand path, ( i think)
    One of the selectiosn will convert a stroke thickness into two cuttable lines, you may have to delete the original centre line.
    The other will outline any line by any distance you enter in MM. Works preety well, but if you start doing big outline on little characters then you will get some strange results.
    BTW it is normal to outline characters by a set distance rather than the stroke the stroke the path option, as this selection inline and outline a character, which may give strange results on letters like W and V etc.
    In the stroke path selction you can also select the round corner outline and other effects.
    Hope that was clear and helps…
  • magpie
    22 November 2003 at 14:03
    It’s tricky coming at illustrator from a sign makers point of view when your used to it
    from a purely digital view.
    I had a play following what you suggested and am very happy with the results.
    It works a treat and yes while playing I did manage to get some strange and interesting
    effects.
