Home Forums Software Discussions General Software Topics How do you constrain movement in Omega
  • George Zerbino
    4 September 2011 at 18:10
    Press "o" on the keyboard to toggle "on axis" on and off. Moving objects will be constrained to their x or y axis depending on movement.
    Press "n" to toggle snap to guidelines on and off.
    Press "g" to toggle snap to grid on and off.
    These 3 will appear as icons at the left of the status bar at the bottom.
    Also, when moving objects with the snap to guidelines and/or grid enabled, if you press and hold shift before moving the object(s) using one of the 9 squares in and around the selected object(s) you will snap to the exact point of selection. Bit hard to explain this in words, your best bet is to try this out, it will then make sense.
    Regards,
    George Z.
  • Jason Davies
    4 September 2011 at 19:21
    Thanks George, you wonder why the just don’t stick to the norm. That’s saved me a load of hassle.
    Jason
  • George Zerbino
    4 September 2011 at 20:23
    I’ve used Omega (aka Grafix Advantage) for 20 years, so for me that is the norm – but I know what you mean.
    Glad to be of help.
    Cheers,
    George
