Home Forums Sign Making Discussions Neon, LED, Lighting how do i trim sheets of acrylic?
  • how do i trim sheets of acrylic?
    Posted by Iain Gordon on 1 August 2005 at 16:49
    First of all, NEVER,NEVER do a job for a 3rd party without checking all the measurements yourself…..
    Now the problem….I have to trim down 2 sheets of acrylic by 200mm (lightbox front)
    1. Can it be done with a variable speed jigsaw?
    2. If so, does anyone know what sort of blade i should use.
    By rights i should just make another one and charge him again, but i’m trying to build a worthwhile relationship.
    Mant thanks
    Iain
    Stephen Morriss replied 20 years, 4 months ago 6 Members · 14 Replies
  • 14 Replies
    1 August 2005 at 16:58
    Yes Iain, it can, a blade is available for perspex. I bought a set of various blades from B&Q Just make sure the material is on a firm surface, If you have 2 pieces to cut use one as the guide for the other.
  • Iain Gordon
    1 August 2005 at 17:04
    Cheers Peter..
    It’s a great industry this…Work for next to nothing and then when it all goes tits up, work for nothing
    Iain
  • Andy Gorman
    1 August 2005 at 17:32
    Use a fine toothed blade. If it overheats and fuses the perspex, put a bit of 3in1 oil or washing up liquid along your cut line.
  • Iain Gordon
    1 August 2005 at 17:35
    Cheers for the tip Big G
    Iain
  • John Cornfield
    1 August 2005 at 21:53
    I would suggest to use a hand router to cut through you will get a cleaner cut edge andyou can also use a jig to help you keep straight.
    john
    1 August 2005 at 22:00
    any blade will cut it, but if you use the one designed for the material, you should not need lubrication,
    A hand router will do the job, but makes loads more dust. You can cut a perfectly straight line with a hand held jigsaw, just like a router, if you use a jig or straight edge to guide it.
  • Iain Gordon
    1 August 2005 at 22:01
    If i was to use a router, could i use normal woodworking bits.
    Sorry if that sounds dumb, but i rally dont know
    Iain
    1 August 2005 at 22:03
    yes Iain, but see above, if its a straight cut, I would go for the jigsaw,
  • Iain Gordon
    1 August 2005 at 22:08
    Peter,
    Jigsaw it is….. going up and down with a bit of lubrication sounds good to me 😀
    Sorry, just thinking aloud there
    Iain
    1 August 2005 at 22:09
    or, if you have a steady hand, and consider yourself a craftsman, you can actually cut it with a crosscut woodsaw. it want get you any more brownie points, but will give you a great feeling of achievement
  • Iain Gordon
    3 August 2005 at 17:58
    Cut the acrylic a treat. Used Blg G’s tip for the lubrication
    I did it with and without washing up liquid to see what the difference was and was amazed at how the acrylic fuses together without
    Iain
  • Andy Gorman
    3 August 2005 at 20:17
    Glad it worked Ok matey.
    Generally speaking the ‘proper’ Perspex made by ICI doesn’t need lubricating, but some of the cheaper brands do. Especially if they are extruded acrylic.
  • Andy Davis
    4 August 2005 at 08:28
    Hi Iain, i use a bosch jig-saw and find that the best blades are T101A0.
  • Stephen Morriss
    4 August 2005 at 09:04
    I use a circular saw bench with a fine TCT blade.
    I nearly fell foul of my own bad measuring with 2 sheets of acrylic, luckly I desided at the last minute not to have the supplier pre cut the sheets for me. When I measured the job again I found I’d measured wrong the first time 😕 That would have been upsetting.
    Measure once cut twice, Doe, I mean measure twice cut once.
