Home Forums Software Discussions Signlab Software how do i transfer files from Illustrator to Signlab?
  • how do i transfer files from Illustrator to Signlab?
    Posted by Keith Nilsen on 28 July 2005 at 19:41
    Hello all…
    I have an opportunity tomorrow to play with a bunch of plotters and printers, and want to try cross-program between Illustrator and Signlab while I have the chance to experiment!!
    Can anyone therefore advise me on the easiest route that an Illustrator file takes to make it a plottable file cut through Signlab? I would appreciate any advice…
    Keith
    Keith Nilsen replied 20 years, 3 months ago 7 Members · 11 Replies
  • 11 Replies
    28 July 2005 at 20:40
    Kieth, I dont use illustrator, but ai files import directly into signlab, or just drag n drop. not sure as to what you mean by the easiest route, though.
  • Keith Nilsen
    28 July 2005 at 20:48
    That sounds like the easiest route!! Thanks Peter!!
    Are there any issues to contend with at all with the imports? There was a recent post that mentioned unwanted lines appearing from one program to another, cured I believe by the weld option. Anything similar happen in the Illustrator to Signlab process?
  • Mike Rogers
    28 July 2005 at 21:25
    When I have imported illustrator files in to signlab (not sure whether they were created in Corel Draw and exported as an illustrator) I find that the plotter cuts around some lines twice. If you click on these lines and delete it is apparent there were two lines there – just one of those bugs really.
    I am sure the same thing happens in Vinyl Master Pro so may be a common thing although not aware it happening in Flexisign
    Mike
  • Keith Nilsen
    28 July 2005 at 21:29
    Hi Mike,
    I would imagine this occurs if there are lines in the original that have stroke width settings applied. This would be treated as 2 lines, an outer and an inner and would be read as such by the plotter. The way around it obviously is merely to get rid of the one unwanted stroke path.
    K
  • Mike Rogers
    28 July 2005 at 21:41
    Keith
    Tha would make sense although I am sure I have created lines (hairline) in Corel and it has still done it. Must experiment a little more with it suspect it might be a Corel thing when exporting in to an ai file
    Mike
  • autosign
    28 July 2005 at 21:51
    Yes they are stroke lines. Flexi has a convert strokes to outlines option.
    28 July 2005 at 22:05
    quote Nike Mike:
    i only ever get two cutting outlines when i request an ai. file thats been exported from a mac 😕
  • Gordon Forbes
    28 July 2005 at 23:20
    Thats why you weld it gets rid of the stroke from eps and .ai files.
  • Keith Nilsen
    29 July 2005 at 09:22
    Thanks to you all for all the comments and replies… a huge help as always!
  • Frank Droog
    29 July 2005 at 13:05
    If you are just cutting, i would try to make sure the line thickness in Illustrator is set to 1 or 0 so that it doesnt come in as a thick line.
    If you are using Illustrator 9 and up, beware that it saves as a PDF file with an AI extension. Depending on the version of Signlab, you may want to save as or export as Illustrator 8 which is the original ai file format.
    frank at cadlink.
  • Keith Nilsen
    29 July 2005 at 16:42
    Thanks Frank, I’ll keep that last bit of information in mind….
