Home › Forums › Software Discussions › Signlab Software › how do i stop object moving fast in Signlab please?
Posted by shaun ramsay signs on 5 March 2008 at 01:58hi,
as soon as i click on an object to move position it instantly goes upwards up the page fast and keeps going until i move it left or right. is this a setting or program problem cause never done it originally so not sure if i accidently done something in my setting etc.thx shaun
Peter Normington replied 17 years, 5 months ago 9 Members · 9 Replies -
Not sure but – maybe your mouse sensitivity has been changed. Use windows control panel to adjust your mouse movement sensitivity – this may help.
I know this might sound a bit obvious, but is there anything leaning on your keyboard or any sticky keys?????
Try going in to options/signlab setup/general preferences and turn off speed scroll to see if it makes a difference. This is the setting which moves the screen around when scrolling past the edge.
Had something similar a month or so ago but with Gerber Omega.
It was the mouse on it’s way out (hot) -
I had a mouse where the pointer would move on its own. Bought a new mouse and everything is fine now. Get an optical one though.
From Mark
thanks to all, will try all suggestions and see whether any work, hopefully it is just my mouse as this is a cheap fix.
Not the same issue as above, but when I want to add duplicate guide lines, or click on a guide, how do you stop it moving that incy little bit… I use the guides lots in creating graphics, and this is one very annoying thing. I have even tried lifting the optical mouse off the table before clicking, but its just as difficult to keep the cursor on the line.
After it has moved the guide a fraction, ctrl+z doesn’t put it back, it just undoes your last edit.Heres hoping someone else has had the same issue.
Sam, I know what you mean and it can be a pain but if you set the selection range to default or one it will help, (Options set up selection tool settings) But then may affect shape selection, if you need to add duplicate guides just right click and use the set up dialogue, lock the guides, and they wont move, but you can still add guides
