Home Forums Sign Making Discussions Off Topic Chat How do i sign up for access?
  • How do i sign up for access?
    Posted by Peter Normington on 28 September 2004 at 20:13
    I have money burning a hole in my pocket. How do i sign up for the ‘extras’ on this site. When iI try to on the home page there dosn’t seem to be any links
    Lee Jones replied 21 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • J. Hulme
    28 September 2004 at 20:49
    http://www.uksignboards.com/
    on the left-hand side, get access is about half way down 😉
    Home
    28 September 2004 at 21:06
    cheers outline 😉
    it can be found on navigation bar on left like has been said mate.
    try this for a direct link
    http://www.uksignboards.com/index.php?nav_0=5
    28 September 2004 at 21:31
    clicked every thing it won’t go help !!
  • J. Hulme
    28 September 2004 at 21:37
    Are your security settings too high?
    28 September 2004 at 21:45
    thanks for that security settings cant be to hi but I turned of zone alarm and behold! I can now subscribe., funny though don’t have to do it for other sites, including credit cards etc. did notice (cynically) loads of adds appeared at the same time
    28 September 2004 at 22:27
    The security on my computer is paramount, I use it for my living, therefore i only access websites that are also security orientated, and never reduce my settings, to accommodate a risk of invasion. ever since the internet started I have never caught a virus or had a hacker problem.(touch wood) am I paranoid?
  • Lee Jones
    29 September 2004 at 09:46
    Hi peter, I don’t think you are being paranoid at all, with the crap and idiots floating around the net, you need the maximum protection you can find
    I used zone Alarm for just over 2 years, and it will successfully block all unwanted entry, except, most of us set it up to block everything using the default settings. But unless you tell zone alarm, it cannot differentiate between so called friendly access and unfreindly (viruses, trojans ,worms etc) especially where ads and active code are concerened, such as active scripts and java scripts.
    Try this:
    Click on PRIVACY in Zone alarm, and if the Ad blocking slider is set to maximum, try moving to Medium or off and see what happens, usually Medium is quite sufficient, and still gives you a high level of security.
    If you want to keep the Ad blocking slider to its maximum setting, then you will have to create a rule that only allows access between your computer and the UKSB web site. This is accessed throught he Expert Tab, with a rule created, everything is fully protected as before, but allowing access to traffic based on the IP address of the source or destination.
    When in the expert section click on help for full instructions for setting up
    Hope this helps
    Lee
